It is safe to upgrade from Zabbix 5.4.0 directly to 5.4.9?
  • jcsenag234
    • Dec 2021
    Hi, good morning.
    I just wondering if is safe to upgrade minor versions skipping and going from 5.4.0 directly to 5.4.9, just to be sure so we can follow the documentation below on updating minor version.
    Regards and thanks in advance.
    Short answer... yes.
    • jcsenag234
      • Dec 2021
      Thank you cyber,
      I got another question, in the article, for the part to upgrade minor version, on the first two commands, what are the difference? And also, which one will do for upgrading a proxy?
      $ sudo yum upgrade 'zabbix-*'
      $ sudo yum upgrade 'zabbix-server-*'
      Thanks in advance.
        First upgrades all packages on server which name is starting with "zabbix",
        Second upgrades all packages on server which name is starting with "zabbix-server"
        Its the simple pattern matching there...
        First one will affect more packages, both server and agent, for example. or proxy and agent if it is proxy host....
