Inventory macro in trigger expression
  • neoflamez
    • Mar 2022
    Hey all,
    Got a situation whereby I want to:
    1. Get the output of a check and populate inventory (done)
    2. Create a trigger using a calculated expression based on the output of the above (struggling)
    It seems you can't use inventory macros in expressions (I don't know why). It also seems you can't set a user macro to be the value of an inventory macro.
    Any ideas gratefully received.
  • Answer selected by neoflamez at 17-03-2022, 17:36.
    LenR
    • Sep 2009
    • 1011
    Here is a trigger that tests the last observation against the avg(7d)*6; or 6x the running average.
    {Elastic Index Watch Counters for ES:watch_counter["filebeat-*",5].avg(7d)}*6<{Elastic Index Watch Counters for ES:watch_counter["filebeat-**",5].last()}
    • LenR
      • Sep 2009
      • 1011
      So you used item -> to inventory? Then trying to use inventory in a trigger? Can't you just use the original item?
        Can you see here anywhere a note, that you can use inventory macros in trigger expressions? You can use user macros there as constants or function parameters. And that's all.
        Assigning one macro to another (ie {$USERMACRO} = {INVENTORY.MACRO} ) does not work also. It will be taken literally, not resolved (again).
        Question remains, why aren't you using item value directly as LenR already pointed out?
        • neoflamez
          • Mar 2022
          Probably should've clarified - Item1 -> inventory. Want a trigger on Item2 to use the value from the inventory (or from item1) in a calculation. Can I refer to Item1.value in Item2.trigger? I wasn't aware this could happen?
          • neoflamez
            • Mar 2022
            Originally posted by cyber
            https://www.zabbix.com/documentation...ed_by_location
            Hey cyber,
            Nope - I didn't see it anywhere - I read the docs and thought I'd give it a go... sometimes these are 'undocumented features'. It clearly didn't work (as the docs point out and as you've pointed out again) so I came to the forum for an answer.... I've answered LenR above, let me know your thoughts.
            • LenR
              • Sep 2009
              • 1011
              • neoflamez
                • Mar 2022
                Thanks Len, I can't believe I didn't see it before but of course I can just multiply by the key of the other Item.... you're a star!
                  Trigger expressions are not limited to one single item. You can compare multiple item values or use them in math operations. Even if LenR shows usage of same item twice (last vs avg over time plus some multiplication), you can compare 2 separate items with each other. item1.last() >item2.last() or item1*item2 > X etc...
                  • neoflamez
                    • Mar 2022
                    Trigger expressions are not limited to one single item. You can compare multiple item values or use them in math operations. Even if LenR shows usage of same item twice (last vs avg over time plus some multiplication), you can compare 2 separate items with each other. item1.last() >item2.last() etc....
                    Yep - just clocked that... appreciate the input.
                    • highpeak
                      • Nov 2019
                      • 30
                      I have the same requirement. I have an inventory field populated via the API (serial number A), and an item that gets the actual device's actual serial number via SNMP and populates serial number B - I want to trigger if serial A is different from serial B (or if last(item) <> inventory.serial.a).
                      Is this not possible?
