Zabbix agent2 - lowering plugin ZabbixSync
  • holantomas
    • Apr 2019
    I still getting error on one server(ubuntu server 20.04) with zabbix agent 2 (6.x - currently 6.0.2). This server randomly reports as unreachable or some monitored service like docker, ssh or others is unreachable. Don't know if error cause this problem but I want to solve that first.
    HTML Code:
    lowering the plugin ZabbixSync capacity to 1 as the configured capacity 100 exceeds limits
    I tried to search configuration for this build-in plugin but didn't found any options how to solve this problem or increase limit. Any suggestions?
  • highpeak
    • Nov 2019
    • 30
    I'm seeing the same thing with 6.0.2 on proxmox. Did you find a solution?
    • jtnfoley
      • Mar 2022
      • 82
      +1 here - googling for answers now.
      • charlesiapp
        • Mar 2021
        Any solution? I have the same problem. Version 6.2.3
        • xyz_zabbix
          • Mar 2021
          I also got this problem on my zabbix 6.2.2
          No solution? How to change the value?
          • BGmot
            • Aug 2017
            Try adding this line to your /etc/zabbix/zabbix_agent2.conf:
            Plugins.ZabbixSync.System.Capacity=1
            • Harish Munagapati
              Harish Munagapati commented
              I have applied the fix and again got the below one
              lowering the plugin WindowsPerfInstance capacity to 1 as the configured capacity 100 exceeds limits
          • Luiz Armando
            • Apr 2024
            Same problem here!
            Masters of Zabbix, we call upon you!
            • roberto_estrada
              • Jun 2024
              Hello, I had the same error as my friends.
              I need to collect data from my Hyper-v Host and the VMs it contains.
              lowering the plugin WindowsPerfInstance capacity to 1 as the configured capacity 1000 exceeds limits
              • z0nk
                • Oct 2024
                • 45
                Same problem on 7.0
