Version compatibility between Solr and Zabbix
  • shekhar.prateek01
    • Jan 2016
    I am quite new to JMX and Zabbix. I want to setup an environment where I can monitor Solr instances using the same. However, I have different versions of Solr installed.
    So, I wanted to ask is there any compatibility issue if I use the same zabbix template and version for different versions of Solr.
