Can Zabbix Agent and Zabbix Agent 2 work together?
  • Hello There
    • Feb 2018
    • 30
    Hello all,
    we use Zabbix 5.0.15 and Zabbix Agent and we are satisfied, all is working as supposed. However, we need to implement a few modbus devices that require the Modbus plugin which means that we have to use Zabbix Agent 2 to be able to add them to Zabbix.
    My question is... Can we use Zabbix Agent and Zabbix Agent 2 concurrently so we don't have to move all devices from Zabbix Agent to Zabbix Agent 2 and just let modbus devices use Zabbix Agent 2?
    Yes, you can put agent2 on selected nodes and continue using classic agent on others.
    • Hello There
      • Feb 2018
      • 30
      That's great. Thank you.
      Then how can I install Zabbix Agent 2 on the Zabbix server?
        Same way as you installed classic agent, just specifying different agent version... (zabbix-agent2).
        • Hello There
          • Feb 2018
          • 30
          OK, thanks.
