No media defined for user
  • cor9957
    • Jan 2014
    • 12
    Hi all,
    We are running Zabbix 6.0.4 on Ubuntu server 20.04
    Everything was working fine, but out of the blue, email stopped working. The error I see is "No media defined for user" for every user in the user group
    I've tried creating a new user group, a new action, changing email server and a new media type, but nothing works.
    We've been using Zabbix since version 3, so I'd like to think I know my way around Zabbix, but this one has me baffled.
    I hope that somebody can point me in the right direction.
    Thanks,
    Cor..
    • 4970
    Is there a media defined in users config? None of those things you did have any effect, if your user(s) has no media in config...
    I kind of doubt, that everything was fine, but "suddenly" email media disappeared from all uses configs... someone poked their greasy fingers into the machine..
    • cor9957
      • Jan 2014
      • 12
      You are absolutely right, I also don't believe it when somebody says "it just stopt working".
      To make things even stranger, Zabbix is running as a VMware virtual machine, this morning I restored a backup from a week ago, and this has the same issue, and I'm pretty sure it was working fine a week ago.
      I just checked, but email media is available for all users involved.
      • IchiNiSanShi81
        • Jun 2022
        I had the same problem and I found the cause on conditions set on action configuration.
        In my case there ware some conditiond "not equal" and "equal" with "AND" as "Type of calculation".
        I cleaned and readd all confitions and that solved the issue.​
