Cannot close problem even manually close enable
  • eglyn
    • Jan 2022
    • 16
    Hi
    I have an issue with Windows service discovery, it discover some services with random character at the end and say that they are not started.
    The close manually is greyout, so I go into the trigger prototype to enable manually close.
    But, even I did that, nothing change, I cannot close the problem... I wait a few days...
    Is there a way to remove this problems ?
    Adjust your discovery rules so those random services will not be discovered...
    • eglyn
      • Jan 2022
      • 16
      I did this, but it does nothing for the existing alerts wich stay displayed.
      • Markku
        • Sep 2018
        • 1784
        You can then just delete the extra items that should not be discovered anymore. The problems will then be deleted automatically.
        Markku
