Item to count number of UP interfaces - HPE switches
  • hemh
    • Apr 2020
    • 43
    Hi forum,
    I need some help to figure out how to make an item to count all UP interfaces on a switch.
    I already got all interfaces operationnal status via LLD, what I need is an item that I will use to calculate the port utiization percentage.
    For example, I got all my interfaces status items keys:
    net.if.status[ifOperStatus.1]
    With latest latest value: up (1)
    I would like an item to calculate all the interface with that latest value. I guess it will be a calculated item?
    Thanks for your help.
  • mbuyukkarakas
    • Aug 2014
    • 49
    Hello, I saw your post. I need the same one.
    I made some researches. There is a trigger function count which gives us the chance of using operators like less than, greater than. https://www.zabbix.com/documentation...ctions/history
    But the problem is, there is no way to calculate "number of up interfaces" in a trigger and create the alert.
    We need something in item functions. But the related item functions dont provides operators. https://www.zabbix.com/documentation...ated/aggregate
    According the documentation, it is not possible to write something like this ;
    count(last_foreach(//net.if.status,1h,"lt",2))
    or
    count_foreach(/*/net.if.status,1h,"lt",2).
    All I can do is ; sum(last_foreach(//net.if.status[*])) but this one is only calculating number of interfaces. Not distinguishing the down or up ones.
    regards.
    • hemh
      • Apr 2020
      • 43
      My question has been resolved, it helped me to make up this template for capacity monitoring. Thanks
