AWS TimescaleDB with Zabbix
  • kchojn
    • Jun 2022
    Has anyone had to experience the cloud TimescaleDb?
    I will deploy Zabbix 6.0 LTS with postgres timescaledb but on virtual machine. I wonder if there will be any problems switching to the cloud version?
    Best Regards,
    Karol!
    • 5008
    If that db with timescale is provided by cloud already... then compression... There are 2 versions of TS plugin licences. https://www.timescale.com/legal/licenses with Apache license you don't get compression, but you cannot use TSL version for free, if you use it to provide timescale as a service..
    if you have whole VM and you do install everything by yourself, then I suppose you can use TSL version, as you are not providing it as service...
