Discovery of single IP with multiple ports
  • Bdoydie
    • Jun 2022
    I'm trying to configure discovery rules on Zabbix 6.0, where we have some network switches that we are using port forwards for,
    ie we have a single IP visible but each port points to a different device
    I can get my SNMP discovery rule working, but my problem is that it will only add a single host and then multiple SNMP interfaces, 1 for each port
    That wont work for me as I need each port monitored independantly to each other.
    I'm using the SNMPv2-MIB::sysName.0 SNMP agent chekc so each port that responds will give a unique response and have the device uniqueness set to the SNMP check.
    Is there a way I can get the discovery action to create a seperate hsot based on the response of the SNMP check?
