check folder size
  • IKI
    • Jun 2022
    check folder size
    Привіт, народ. У мене виникла проблема з налаштуванням тригера для перевірки розміру папки
    Using the vfs.dir.size key [{$ FOLDER}], I get the folder size.
    There is a problem setting up verification. I need this if the folder size is now smaller than it was last time - the trigger worked
    I have such a trigger now - {folder:vfs.dir.size[{$FOLDER}].now()} < {folder:vfs.dir.size[{$FOLDER}].last()}
