I have found a few posts regarding this issue, but nothing has let me so far anywhere. I am trying to exclude unused (disconnected) network interfaces from the reported data by using a filter and not manually disable them in the result for the device, etc. Details are:
Zabbix 6, Template is a slightly changed (for OIDs mostly) copy of Cisco Catalyst 3750V2 SNMP
Example data to be filtered: Interface te1/0/14(), where te1/0/14 is {#IFNAME} and () is {#IFALIAS} (from the template)
Macro in the template is {$NET.IF.IFALIAS.EMPTY}, Value: "Null"
I added one more Filter to the standard ones from the template: {#IFALIAS} does not match {$NET.IF.IFALIAS.EMPTY}
Latest data shows all network ports, connected or not.
Any suggestions on how to go about this? Any changes for the macro other than keeping it null?
Thanks.
Thanks.
