Frontend's wrong timezone display
  • markfree
    • Apr 2019
    • 875
    I'm getting a timestamp in unix format that is being displayed in the frontend with the wrong timezone.
    For example:
    My item receives a value of "1657361472" and its unit is set as "unixtime".
    When I check the latest data, the item displays the wrong time.
    That value should be translated as "2022-07-09 10:11:12" in the frontend, but it is displaying "2022-07-09 07:11:12".
    The value is correct, but the presentation is not.
    Of course, my frontend is configured with GMT-3, which is my time zone.
    How can I display the timestamp value ignoring my frontend's timezone?
  • Markku
    • Sep 2018
    • 1784
    1657361472 = Saturday, July 9, 2022 10:11:12 AM (UTC)
    and you are in UTC-3
    so displaying 07:11:12 seems correct to me.
    AFAIK the unix timestamp is based on UTC, not on local time.
    I guess you need to change your frontend configuration if you want to show the data in other timezone.
    Markku
    • Hamardaban
      • May 2019
      • 2714
      Pls check this: https://www.zabbix.com/documentation...e/user_profile
      • markfree
        • Apr 2019
        • 875
        I understand.
        I just thought Zabbix would not consider the profile timezone when displaying the data (a good thing, I know).
        At the source host, I had to transform the collected timestamp to make it standard UTC.
        It would be nice to have a "unixtimenoutc" as a unit type, I guess.
        • Markku
          • Sep 2018
          • 1784
          You can also use item preprocessing to fix the value in Zabbix.
          Markku
          • markfree
            • Apr 2019
            • 875
            Indeed, but I don't see how.
            In my example, the value "1657361472" represents, "Sat Jul 09 2022 10:11:12". Since it was captured from another system, it was originally set as UTC-3.
            For it to become UTC-0, I could just add 10800 seconds (3h). It would become "1657372272" which represents "Sat Jul 09 2022 13:11:12".
            How could I add those 3h with preprocessing?
            • Markku
              • Sep 2018
              • 1784
              Based on the documentation (https://www.zabbix.com/documentation...ing/javascript) this JavaScript preprocessing step could work:
              return value + 10800;
              Let us know how it goes.
              Markku
              • markfree
                • Apr 2019
                • 875
                I forgot about Javascript.
                Anyhow, I actually altered the timezone at the source. Now, the unix time collected is matching UTC-0.
                Thanks a lot for all considerations.
