Zabbix agent is not available
  • Jack0
    • Mar 2022
    • 21
    Hello everyone,
    I have a little question, i have to monitor a Windows Server with MSSQL on it, but when i install the agent (i did it on another Windows server and i don't have any problems with it) in my dashboard they appear as unavailable (the little box is grey ).
    So my question is what's the matter with my agent.
    here the configuration
    and on the agent side i configured
    server = <my ip zabbix>
    Listenport = 10050
    ServerActive = <my ip zabbix>:10051
    Hostname = <my hostname>
    the two hostname match and i do receive data but not all data.
    What did i do wrong ?
  • Answer selected by Jack0 at 15-07-2022, 08:08.
    Markku
    • Sep 2018
    • 1784
    AFAIK even a single working passive item on a host will get the host status to green (talking about Zabbix 6.0 or older here), so that's why some of your "active" agents are green.
    Markku
    • Jack0
      Jack0 commented
      Understood i need to have a least one PASSIVE agent working to have the status in green.
      Thanx a lot ! even if its a stupid question
  • Markku
    • Sep 2018
    • 1784
    Search for "zabbix agent grey" or read the documentation (https://www.zabbix.com/documentation...guration/hosts) and you'll see that active agent status is not ever going to go green in Zabbix 6.0 or older.
    Also see what's new in Zabbix 6.2: https://www.zabbix.com/documentation...t-availability
    If you also have passive items and they are not working, normal troubleshooting steps apply: why doesn't server reach the agent (see the logs of the server and agent).
    Markku
    • vladimir_lv
      • May 2022
      • 240
      Hi!
      Can you see this Windows Server data in the Latest data? Have you used the Zabbix proxy?
      • Jack0
        Jack0 commented
        i do receive data in the latest data but there refresh time is not matching the configuration --> like for the the cpu its supposed to refresh every minutes but when i check the data the latest refresh is 2 minutes, no i used zabbix agent, never used zabbix proxy
    • Jack0
      • Mar 2022
      • 21
      Thanx for your answer Markku, i've checked the log and they said my client can't connect to my server --> i corriged
      i don't understand cause i have some other host (on linux) and they do have the green box
      Click image for larger version  Name:	2.png Views:	0 Size:	53.8 KB ID:	447891
      also i've read the doc but they said is gray if the interface is unknow but i do receive data from the active check.
      i do have passif item for mssql but one step at a time
      • Markku
        • Sep 2018
        • 1784
        Markku
        • Jack0
          Jack0 commented
