MySQL: Buffer pool efficiency
  • LenR
    • Sep 2009
    • 1011
    My Zabbix 6.0 server is getting a very low value for this item, .02. I think the value is the inverse of "buffer hit ratio", I'm getting very few actual buffer reads/sec but a lot of requests. How is this value interpreted? Is low good?
  • admin@psmnv.com
    • May 2022
    • 41
    I have the same question, in case you ever found an answer.
    • joanaribeiro_erre
      • Jul 2020
      • 25
      anyone has any ideas?
        https://dev.mysql.com/doc/refman/8.0...ffer-pool.html
        and
        https://git.zabbix.com/projects/ZBX/...%2F6.4#112-116
        I would assume, that higher number is better. It means, that your more often used data is cached in memory and your get your results quicker.
