What happens if I: Agent Update?
  • TecDragon
    • Nov 2019
    • 63
    If I download the new 6.2 agent and push it to machines running the 6.0 agent using something like PDQ deploy. Will the config file get overwritten? I have 25 sites running individual proxies reporting back to a cloud based server, it took forever to set these up initially and I don't want to break all of the connections, but I do want to stay up to date. If the config doesn't get overwritten by pushing out a new agent that would be great, if it does that means I have to create 25 separate upgrade jobs. Either way will work but obviously one is far easier than the other.
  • Markku
    • Sep 2018
    • 1784
    I've used the officially packaged agents on Debian servers for years, and I have never had the agent install/upgrade overwrite my configurations and auxiliary files in /etc/zabbix/zabbix_agentd.d. Also, removing the agent leaves the zabbix_agentd.d files there.
    Markku
    • TecDragon
      • Nov 2019
      • 63
      Thank you! I appreciate the information.
