Problem to configure Gmail
  • Yehudi
    • Feb 2016
    • 12
    Good morning,
    I am having trouble in setting Gmail. You know tell me where to stay the email log file of Zabbix ?
  • mykolaq
    • May 2015
    • 69
    Originally posted by Yehudi
    Good morning,
    Do you mean email notifications? i advice you something like this https://karp.id.au/post/smtp_zabbix/
    • guiip
      • Mar 2016
      I have been tried this tutorial but though status is 'Sent' in Actions Log I don't receive the message in the email. Running the script echo "Message" | /usr/bin/mail -s "Body" "[email protected]" it's works like a charm. In /var/log/mail.log nothing appear of error. I am using ssmtp and gmail.
      Anyone can help me?
      • mykolaq
        • May 2015
        • 69
        Anyone can help me?
        Strange, for me it works. You can also update your Zabbix to 3. It works with smtps ok without any scripts, just standart email channel
        • guiip
          • Mar 2016
          Thankyou for quick reply mykolaq.
          I am using Zabbix 3.0 but I don't know how set fields for Gmail. smtp.gmail.com would be SMTP Server or SMTP helo? SSL in both or only host?
