Multiple zabbix agents with different versions
  • vnbgv
    • Jul 2022
    I am in a situation where I have production zabbix environment (zabbix server and zabbix agent are 2.0 ) (all centos 7), now I am trying to replicate this setup with zabbix 6.0
    I have setup zabbix 6.0 server on a new linux server, trying to add all hosts to this without impacting the production setup
    I was able to do this by referring to https://www.zabbix.com/forum/zabbix-...e-zabbix-agent
    But have a couple of questions
    1.This kind of setup does not give me flexibility to see service status like - service zabbix-agent status, and will have to rely on ps aux
    2. Is it possible to run 2nd agent through a systemd service - zabbix-agent2.service
    3. The second agent I am running is also 2.0, can I run multiple versions of agent on the same machine
    4. are zabbix server 6.0 and agent 2.0 compatible (is there any feature loss in this kind of setup)
    if mentioned points are possible, please provide or redirect me to any good documentation which details these steps.
  • vladimir_lv
    • May 2022
    • 240
    Yes, you can use multiple agents, but for different ports.
    Here is a dispute about Zabbix server 6 and agent 2 compatible
    • vnbgv
      vnbgv commented
      Thank you, I managed to run multiple agents, now looking for possibility of running different versions of agent on same machine (for example 1st agent instance is 2.0 and 2nd agent instance is 6.0)
  • vladimir_lv
    • May 2022
    • 240
    Yes, it'd possible, just use different ports for each instance.
    • Markku
      • Sep 2018
      • 1784
      Also note that if you don't need passive items at all, you can configure the agents with StartAgents=0, then the agents don't listen any ports so there is no need for special agent port configurations anywhere. Some security teams also like that unused ports are not opened. (This is valid for classic agent only, agent2 (the Go version) does not have that setting.)
      Markku
