I am gettting an email laerts from zabbix. It is warnings how can i stop zabbix to send warnings alerts. Also I am not understand how zabbix sends warnings on 0.93%. is there any way to change the value. If value greater then 70% then we receive the zabbix alert.
Trigger: Disk I/O is overloaded on Om
Trigger status: OK
Trigger severity: Warning
Trigger URL:
Item values:
1. CPU iowait time (Om:system.cpu.util[,iowait]): 0.93 %
2. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
3. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
Original event ID: 20407
Trigger status: PROBLEM
Trigger URL:
Item values:
1. CPU iowait time (Om:system.cpu.util[,iowait]): 28.75 %
Original event ID: 18705
Trigger status: OK
Trigger URL:
Item values:
1. CPU iowait time (Om:system.cpu.util[,iowait]): 1.54 %
Trigger status: OK
Trigger URL:
Item values:
Trigger URL:
Item values:
Trigger status: OK
Trigger URL:
Item values:
