Hi guys,
I have configure the alerts and tested and i got some confused on the results.
For testing purpose, I configure the alert to monitor admin status of a switch port. When i disable the port, the trigger works and the status shows "Problem" which is the result i wish. However, after 1 minutes, the status change to"OK" but the port is still down.
Can anyone advise where to change this so when the port down, it will always shows "Problem" and not change to "OK".
Thank you very much.
