How to get metric from python script
  • scav
    • Aug 2022
    Hi, I'm working on a python script to send logging details to zabbix. The machine where I'm working (linux Ubuntu) is already monitored through the agent installed and it is sending everything to the server with no issues.
    After some research i found that i can send to my server logging details from python script using this:
    from pyzabbix import ZabbixMetric, ZabbixSender
    # Send metrics to zabbix trapper
    packet = [
    ZabbixMetric('hostname1', 'test[cpu_usage]', 2),
    ZabbixMetric('hostname1', 'test[system_status]', "OK"),
    ZabbixMetric('hostname1', 'test[disk_io]', '0.1'),
    ZabbixMetric('hostname1', 'test[cpu_usage]', 20, 1411598020),
    result = ZabbixSender(use_config=True).send(packet)
    source: https://github.com/adubkov/py-zabbix#readme
    If I'm not wrong this should work without inserting any information, given that the python library is taking all the details from my config file: /etc/zabbix/zabbix_agentd.conf (source: https://py-zabbix.readthedocs.io/en/...art_guide.html), is this correct?
    If i run the script no errors are showed up so i assume that my script is sending something?
    Last and most important question how can i map this from the server side, i have already been inserting new items under "configuration" -> "Templates" -> items but i don't know how to instruct the server to look for that specific key, Type and so on...
  • tim.mooney
    • Dec 2012
    • 1436
    When you assign a template to a host, all the items, triggers, graphs, etc. that are part of that template are applied to that host.
    • scav
      • Aug 2022
      hi tim.mooney , I'm adding an item to an existing template. this link is usefull: https://www.zabbix.com/documentation...items/item/key thanks, but given the code posted above what would you suggest to change on the screenshot below?
      if this is the metric ZabbixMetric('hostname1', 'test[cpu_usage]', 2),
      key=test ?
      type?
        • 4969
        key=test ?
        type?
        No... Key is "test[cpu_usage]"
        type is "Zabbix trapper". (your script even says "Send metrics to zabbix trapper".. )
        • scav
          • Aug 2022
          Hi cyber thank you very much! It is now working pefectly!!
