Excluding a VM from VMware auto discovery
  • gopkris2000
    • Feb 2020
    • 15
    I used the below template to monitor all my VMware vCenter VM and Hosts. It is working fine. I want to exclude a few VMs that is not required for monitoring and tried to disable those VMs but that is not working properly, I mean it keeps sending alerts.
    Is there any way to exclude it from the auto-discovery?
    You probably need to edit discovery rule (Discover VMware VMs) and add some filters.
    • cojaxx
      • Oct 2023
      Did you end up figuring out the filters to do this? I've got the same requirement
      • xijinping1
        • Aug 2025
        Create this filter in the VMware VM FQDN discovery filter section for every VM that you don't want to appear in Zabbix monitoring:
        For example, if the VM name is VM1, then put ^VM1$
