Monitor Switches deployed behind broadband connection
  • superlava
    • Nov 2021
    • 26
    We've multiple remote locations where we use broadband circuits with static IP for internet connection. Broadband circuit is connected to a firewall after which we've 1 switch and 5 AP's. Now we need to monitor the status(ping) of these switches and AP'. Our Zabbix instance is in AWS, Is there any way to monitor these AP's and Switch without using a proxy. Because we've 100 sites it would be very difficult deploy and maintain 100 proxies for these remote sites.
    Thanks In Advance
  • Hamardaban
    • May 2019
    • 2714
    It is possible if the ranges of ip addresses in the subnets behind the firewalls are different and you can build a VPN from the zabbix server to the firewall.
    • superlava
      superlava commented
      Yes this makes sense. Thank You
