Rename items
  • Hnk
    • Sep 2022
    Rename items
    Hello, Is it possible to rename an item from an official template?
  • Hamardaban
    • May 2019
    • 2714
    Of course you can! Do whatever you want with them. :-)
    • Hnk
      • Sep 2022
      I would like to change the name to "({#FSNAME}): Space utilization", but it doesn't allow. Is there any other way to rename?
      • Hamardaban
        • May 2019
        • 2714
        You need to change it in the template where the prototype was originally described.
        But you want to change in the template that inherited this prototype from another template. Edit the parent!
