Two triggers, ping not responding and agent not running into disaster alert
  • greavette
    • Jul 2015
    • 82
    Is there a way or post that can help me build a disaster alert on my dashboard where if a host has both the agent not running and pinging the host fails a disaster alert is raised?
    Thank you.
  • Answer selected by greavette at 26-10-2022, 13:57.
    cyber
    • 5008
    You have selected "!Multiple" for event generation mode... that's why you get it so many times...
    • greavette
      • Jul 2015
      • 82
      Can anyone point me to how I can setup this type of alert scenario in Zabbix.
      Thank you.
      • greavette
        • Jul 2015
        • 82
        Hello Forum,
        I've made some progress with my setup. I have created a trigger on an existing zabbix agent template (can be either windows or linux)
        The expression I'm using is:
        last(/Linux by Zabbix agent/zabbix[host,agent,available])=0
        I then did a test on my linux server and stopped the agent. I did receive a Disaster alert for this ping and agent not responding trigger I created. But the problem is that the alert in my dashboard spawned a new alert every minute. For the duration of my test, I had many of the same alert in my Zabbix dashboard for this one Trigger. How do I adjust this trigger to only show up once in my dashboard? I want the trigger to keep checking until the agent is running and pinging again. Here is a screenshot of the trigger I created:
        Any advice you can provide would be greatly appreciated.
        Thank you.
          • 5008
          • greavette
            • Jul 2015
            • 82
            Thanks very much cyber for pointing this out to me! I had thought multiple was needed since I was referencing two items.
            Follow-up question fo you. I'm attempting to make a new trigger of a disaster alert that will be a confirmation for me that a server is hard down. My thought was to use the agent not responding and to ping the host. What does my Expression check?
            I would like to check the agent and perhaps a second check of ICMP Pinging the host as well. If both fail then that tells me more confidently that the host may be down and a critical alert is sent to my Dashboard. What does agent/zabbix[host,agent,available] actually mean?
            Thank you.
              • 5008
              Thank you.
              "Linux by Zabbix agent" is template name.
              zabbix[host,agent,available] is an item key for internal item which basically checks if agent interface is available.
              zabbix[host,<type>,available]
              Availability of the main interface of a particular type of checks on the host. 0 - not available, 1 - available, 2 - unknown. Valid types are:
              agent, snmp, ipmi, jmx
              The item value is calculated according to configuration parameters regarding host unreachability/unavailability.
              This item is supported since Zabbix 2.0.0.
              Expression can alway use multiple items, like "last of agent availability is failed AND last of ping ​is failed" you just need to construct the one you like a suits your needs.
              • greavette
                • Jul 2015
                • 82
                Hello cyber, thank you for this explanation...could you help me with what expression I would need to use to have a trigger that will:
                Check Ping
                and
                Check Zabbix agent availability
                and
                if both of the above items fail a critical alert will be created.
                I'm not sure what the expression would look like. I know I'll receive a high alert for ping and a high alert for the Zabbix agent not running. But I'd like to combine these item checks in a trigger to give me a disaster alert. In this way I can be more sure that the host is really down and not just that the agent isn't running.
                I tried the following expression:
                last(/Linux by Zabbix agent/zabbix[host,agent,available])=0 and last(/ICMP Ping/icmpping)=0
                But I received an error that said "Trigger "Ping and Agent Not Responding" belong to templates with different linkages.​"
                Also, since I'm combining two items from two different templates, what happens if I didn't add the ICMP Ping template for example and I added this new item to my Linux Agent template. Would my new trigger fail because it couldn't get data from both items?
                Thank you.
