Does Zabbix support OAuth2 ?
  • rocklee44
    • Apr 2015
    Hi all,
    My environment : Centos 7.6 , php5.4 , mysql5.6 , zabbix4.2 .
    Email settings : legacy basic authentication to Microsoft 365.
    As most provider’s are phasing out Basic Authentication (username + password) for Modern Authentication (OAuth2) , MS is planning to turn off Basic Auth so I want to switch to OAuth2 on my zabbix email settings.
    Does Zabbix 6.x support OAuth2 ? Which version should I choose for upgrading and please give me document guide for configuring OAuth2 on zabbix if you have, thank you very much.
  • Answer selected by rocklee44 at 18-10-2022, 09:54.
    Bartosz Mickiewicz
    • Oct 2022
    • 27
    As far as I know, it's not on the roadmap and not supported, you would have to be creative here, setting up an SMTP relay can be an option, you can also reach out to MS, they have to be prepared for such a scenario. It might be helpful to look for a workaround for printers, in most cases they won't support modern auth.
    • Bartosz Mickiewicz
      • Oct 2022
      • 27
