Zabbix - Jira servicedesk Invalid Request key
  • yorannic
    • Nov 2022
    Hi im trying to use the zabbix / jira integration but every time im trying it with a trigger i get this issue:
    When im doing a test from the media types itself it works.
    Anyone know how ot fix this?​
  • yorannic
    • Nov 2022
    anyone can help?
    • weird_fishes
      • Aug 2024
      Hello, did you solve this issue? I have the same problem with Jira integration, the task itself can be made trough test in media types, but when the actual trigger comes, there is that error with sending.
      • weird_fishes
        • Aug 2024
        It ended up being a network issue, jira bot couldn't receive the task number from jira.
