Monitor IBM Cloud - Best practise?
  • Peter_Gustavsson
    • Nov 2022
    Hi.
    I got the question from a customer to aid them with the monitoring of their environment.
    Their environment is a mixed Windows / Linux / Kubernetes that is hosted in IBM Cloud.
    What would you suggest to be the best practice of monitor it?
    Are there a portal integration available to Zabbix? Or is it to install agents with/without proxy?
  • Peter_Gustavsson
    • Nov 2022
    Anyone that got any ideas regarding this?
      • 4985
      Available integrations are listed here https://www.zabbix.com/integrations
      I do not see anything for IBM Cloud... So you are in a pickle here... Have to work out your own solution...
