Zabbix Agent2: Script topic questions
  • andreas777
    • Jul 2022
    • 16
    Hi there!
    Information:
    Zabbix-Version: 6.0.5
    Zabbix-Agent: Zabbix Agent2
    Monitored Host: Windows 10 Pro
    I have a few questions regarding the execution of scripts on monitored hosts (Zabbix Agent2).
    Firstly, I have succesfully created Items which retrieve values from the Zabbix Agent by executing a script.
    1. Now, I want to run a script on the monitored host if an event is generated by a specific trigger. --> How may I achieve this?
    2. And I also want to create a Script on the Zabbix Frontend which can be run manually. --> How may I achieve this?
    3. Which user is used for executing scripts on a Windows Host (monitored by Zabbix Agent2).
    Could someone please provide the necessary steps for me, so I can compare them with what I did so far and hopefully find my fault?
    Note: I read the documentation, blogs, forums, youtube, etc. but it still doesn't work. I tried lots of different ways. That's why I am not describing what I did so far, cause it may be confusing.
    • 4963
    1. configuration .> Actions https://www.zabbix.com/documentation...cations/action
    2. Administration -> Scripts https://www.zabbix.com/documentation...ration/scripts
    3. Look into service config, But by default "Local system account", I think
    • erezsandel
      erezsandel commented
      What configuration is needed on the agent side in order for this to work?
      I have tried this way and although the zabbix-agent.log says the commands have been executed, I do not see them taking effect on the machine.
