Template version conversion
  • maria_abr
    • Jul 2021
    Is it possible to convert Zabbix template from newer to older version?
    As example version 6.0+ template to be converted to version 5.0 or 5.2.
  • Markku
    • Sep 2018
    • 1784
    It depends on the template contents: if the template uses features that don't exist in the older version of Zabbix then it is not possible. But if the problem is just the changed syntax of the template file, then you can manually edit and contruct a template file that is compatible with your older Zabbix.
    There are no generic instructions for that (AFAIK), so you need to download some other compatible templates for those versions and compare their contents manually.
    Markku
    • maria_abr
      maria_abr commented
      Thank you for the good explanation.
    • 4970
    Do you really need to convert them? I remember downloading from 4.4 and uploading to 6 went without any issues...
    • Markku
      • Sep 2018
      • 1784
      Upgrades are supported, but downgrades are not
      Markku
        cyber commented
        ahh .. need to read properly..
