items units questions
  • ANDros
    • Nov 2020
    I created some items on zabbix that get the values in MB from a bash script, I created the items setting as units M (Megabytes). Consulting the data on the graphs, I see that when the value received exceeds 1000 MB, zabbix converts the value marking it as 1.0 KM instead of 1GB.
    How do I correct this problem ?
    My version of zabbix server/agent is 6.0.12
    Thanks in advance for your support​
  • Markku
    • Sep 2018
    • 1784
    Set item units to B and add preprocessing rule with custom multiplier of 1048576.
    Markku
    • ANDros
      • Nov 2020
      I reported the output of my script in bytes, changed all the items with units B and set the custom multiplier in pre-processing to 1024.
      Now zabbix calculates the values correctly
      Thank you.​
        If you send "bytes" and your unit is also B, then you should not need any preprocessing there... Just saying.
