error in zabbix installation. need urgent help.
  • nafeeskhan
    • Dec 2022
    I was installing zabbix 6.2 at oracle linux 9 and got this error in zcat command
    zcat /usr/share/zabbix-sql-scripts/mysql/server.sql.gz | mysq l --default-character-set=utf8mb4 -uzabbix -p zabbix
    Enter password:
    ERROR 1050 (42S01) at line 1: Table 'role' already exists
    I am showing zabbix server status. and in the end show the zabbix logs.​
    $ systemctl status zabbix-server.service
    ● zabbix-server.service - Zabbix Server
    Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
    Active: activating (auto-restart) (Result: protocol) since Tue 2022-12-13 12:06:19 PKT; 4s ago
    Process: 111647 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
    CPU: 20ms​
    tail -f /var/log/zabbix/zabbix_server.log
    111705:20221213:120945.059 Web monitoring: YES
    111705:20221213:120945.059 VMware monitoring: YES
    111705:20221213:120945.059 SMTP authentication: YES
    111705:20221213:120945.059 ODBC: YES
    111705:20221213:120945.059 SSH support: YES
    111705:20221213:120945.059 IPv6 support: YES
    111705:20221213:120945.059 TLS support: YES
    111705:20221213:120945.059 ******************************
    111705:20221213:120945.059 using configuration file: /etc/zabbix/zabbix_server.conf
    111705:20221213:120945.061 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    111715:20221213:120957.308 Starting Zabbix Server. Zabbix 6.2.6 (revision 6981d8b729a).
    111715:20221213:120957.308 ****** Enabled features ******
    111715:20221213:120957.308 SNMP monitoring: YES
    111715:20221213:120957.308 IPMI monitoring: YES
    111715:20221213:120957.308 Web monitoring: YES
    111715:20221213:120957.308 VMware monitoring: YES
    111715:20221213:120957.308 SMTP authentication: YES
    111715:20221213:120957.308 ODBC: YES
    111715:20221213:120957.308 SSH support: YES
    111715:20221213:120957.308 IPv6 support: YES
    111715:20221213:120957.308 TLS support: YES
    111715:20221213:120957.308 ******************************
    111715:20221213:120957.308 using configuration file: /etc/zabbix/zabbix_server.conf
    111715:20221213:120957.310 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    111719:20221213:121009.362 Starting Zabbix Server. Zabbix 6.2.6 (revision 6981d8b729a).
    111719:20221213:121009.362 ****** Enabled features ******
    111719:20221213:121009.362 SNMP monitoring: YES
    111719:20221213:121009.362 IPMI monitoring: YES
    111719:20221213:121009.362 Web monitoring: YES
    111719:20221213:121009.362 VMware monitoring: YES
    111719:20221213:121009.362 SMTP authentication: YES
    111719:20221213:121009.362 ODBC: YES
    111719:20221213:121009.362 SSH support: YES
    111719:20221213:121009.362 IPv6 support: YES
    111719:20221213:121009.362 TLS support: YES
    111719:20221213:121009.362 ******************************
    111719:20221213:121009.362 using configuration file: /etc/zabbix/zabbix_server.conf
    111719:20221213:121009.364 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    111722:20221213:121021.556 Starting Zabbix Server. Zabbix 6.2.6 (revision 6981d8b729a).
    111722:20221213:121021.556 ****** Enabled features ******
    111722:20221213:121021.556 SNMP monitoring: YES
    111722:20221213:121021.556 IPMI monitoring: YES
    111722:20221213:121021.556 Web monitoring: YES
    111722:20221213:121021.556 VMware monitoring: YES
    111722:20221213:121021.556 SMTP authentication: YES
    111722:20221213:121021.556 ODBC: YES
    111722:20221213:121021.556 SSH support: YES
    111722:20221213:121021.556 IPv6 support: YES
    111722:20221213:121021.556 TLS support: YES
    111722:20221213:121021.556 ******************************
    111722:20221213:121021.556 using configuration file: /etc/zabbix/zabbix_server.conf
    111722:20221213:121021.559 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    111725:20221213:121033.808 Starting Zabbix Server. Zabbix 6.2.6 (revision 6981d8b729a).
    111725:20221213:121033.808 ****** Enabled features ******
    111725:20221213:121033.808 SNMP monitoring: YES
    111725:20221213:121033.808 IPMI monitoring: YES
    111725:20221213:121033.808 Web monitoring: YES
    111725:20221213:121033.808 VMware monitoring: YES
    111725:20221213:121033.808 SMTP authentication: YES
    111725:20221213:121033.808 ODBC: YES
    111725:20221213:121033.808 SSH support: YES
    111725:20221213:121033.808 IPv6 support: YES
    111725:20221213:121033.808 TLS support: YES
    111725:20221213:121033.808 ******************************
    111725:20221213:121033.808 using configuration file: /etc/zabbix/zabbix_server.conf
    111725:20221213:121033.810 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    111728:20221213:121046.057 Starting Zabbix Server. Zabbix 6.2.6 (revision 6981d8b729a).
    111728:20221213:121046.057 ****** Enabled features ******
    111728:20221213:121046.057 SNMP monitoring: YES
    111728:20221213:121046.057 IPMI monitoring: YES
    111728:20221213:121046.058 Web monitoring: YES
    111728:20221213:121046.058 VMware monitoring: YES
    111728:20221213:121046.058 SMTP authentication: YES
    111728:20221213:121046.058 ODBC: YES
    111728:20221213:121046.058 SSH support: YES
    111728:20221213:121046.058 IPv6 support: YES
    111728:20221213:121046.058 TLS support: YES
    111728:20221213:121046.058 ******************************
    111728:20221213:121046.058 using configuration file: /etc/zabbix/zabbix_server.conf
    111728:20221213:121046.060 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    111731:20221213:121058.307 Starting Zabbix Server. Zabbix 6.2.6 (revision 6981d8b729a).
    NOW I want to resolve my issue. plz help.
  • Atsushi
    • Aug 2013
    • 2028
    The table is created, but it seems that the data is not registered. Wasn't an error output when you first registered the initial data? Please try recreating the database.
    • nafeeskhan
      • Dec 2022
      Yes want help in recreating database. as I have no proper knowledge of database.
      tried executing the command again and it gives error
      Enter password:
      • Atsushi
        • Aug 2013
        • 2028
        Delete the database with the drop database command, and then create the database again with the create database command.
        ex.
        # mysql -uroot -p
        password
        mysql> drop database zabbix;
        mysql> create database zabbix character set utf8mb4 collate utf8mb4_bin;
        mysql> set global log_bin_trust_function_creators = 1;
        mysql> quit;​
