send alert message when my alert is resolved,means it does't send recovery message
  • iqsing
    • Dec 2022
    zabbix version:2.4.8
    alert message is ok, but i will receive a alert message when alert is sloved , i can receive recovery message.
    i can't see anything ref from log. i have try to delete and rebuild the config of action or restart zabbix-server but it not work.
    what should i do now ? i need you help
    i have enable the recovery message.
    this is my configuration of action:
    Default subject:
    {TRIGGER.STATUS}: {TRIGGER.NAME}
    Default message:
    Trigger: {TRIGGER.NAME}
    Trigger status: {TRIGGER.STATUS}
    Trigger severity: {TRIGGER.SEVERITY}
    Trigger URL: {TRIGGER.URL}
    Item values:
    1. {ITEM.NAME1} ({HOST.NAME1}:{ITEM.KEY1}): {ITEM.VALUE1}
    2. {ITEM.NAME2} ({HOST.NAME2}:{ITEM.KEY2}): {ITEM.VALUE2}
    3. {ITEM.NAME3} ({HOST.NAME3}:{ITEM.KEY3}): {ITEM.VALUE3}
    Original event ID: {EVENT.ID}
    Recovery message
    Recovery subject:
    recovery{TRIGGER.STATUS}: {TRIGGER.NAME}
    Recovery message:
    revocery
    i get the message this:
    Subject:
    OK: relication delay > 5s on port 13302
    Message:
    Trigger: relication delay > 5s on port 13302
    Trigger status: OK
    Trigger severity: High
    Trigger URL:
    Item values:
    1. MySQL replicate delay on port 13302 (mysql-nouse:mysql.multi.replicate_delay[13302]): 3
    2. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
    3. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
    Original event ID: 304461​
