Extra schedule entry
  • Puffer
    • Jan 2023
    • 9
    Hi Folks
    I have a calculation that needs to run at 5am each day, this works perfectly, however when I look at the "latest data" there is a 2nd run of the calculation just before 20h00 each day as well, which I don't need or want.
ID:	457161Click image for larger version
    Am I doing something wrong​​ ? Could there be a global schedule that is adding this 2nd entry ?
    Set "update interval" to 0. I suppose you updated your item ~19:58 at some day...?
    Note: The update interval can only be set to '0' if custom intervals exist with a non-zero value. If set to '0', and a custom interval (flexible or scheduled) exists with a non-zero value, the item will be polled during the custom interval duration.​
