SMS limit for a day
  • sandissostaks
    • Jan 2023
    SMS limit for a day
    Greetings!
    I am looking for solution to limit SMS notification count for user per day. Is it even possible to do on zabbix right now?
    I looked trough zabbix documentation as well looked trough forum and searched on google, but did not find any solution for this.
    Looking forward for some tips and help!
    Thank you.
  • sandissostaks
    • Jan 2023
    No one have ideas?
    • Hamardaban
      Hamardaban commented
      "on zabbix right now" - no way.
  • sandissostaks
    • Jan 2023
    Hamardaban Thanks for answer!
    • markosa
      • Aug 2022
      • 106
      If you create own script which keeps a track how many sms's has been sent to user then it's possible.
      • sandissostaks
        • Jan 2023
        markosa Sounds like some kind of idea. Will try to make a script. Thank you!
        • fvilarnovo
          • Jan 2023
          • 17
          Hi!,
          This could not be the best or most elegant solution, but hey maybe sparks some ideas... you could add an additional media type, script, that writes the date and a "1". This could be to a temp file or a new table in your database.
          In your trigger action that uses sms, add an additional step to use that media type, so each time you send an sms, a 1 and date will be written somewhere.
          Add a new item (type external check) where you will run your query, schedule it at 23:59. Remember in the logic of your script to purge those values from time to time.
          Profit
          Hope it help!
          • sandissostaks
            • Jan 2023
            fvilarnovo This could work for me. Thank you.
