i have the situation that my nodes are "blinky" on nearly all Tests / Triggers the first Hour after they got Recoverd. After this hour they get the state "ok", but before they say "ok" "problem" "warning" etc in a high amount.
So is there an option to "mute" a node in the first hour after recovery?
Because its rly annoying to get 15 to 30 mails after a new node joined.
Also there is another problem with my zabbix.
I have One old node i cant delete.
I can rename it, i can disable it, but i cant delete it.
It has a huge amount of items (818) and graphs (404) maybe this is the problem?
I got no error message, but if i want to delete it, i will be redirected to an empty "hosts" site.
Regards
Regards
So its gone now *happy*
