inconsistent ifHC data
  • dalamar
    • May 2016
    All,
    I am running Zabbix 2.2.11 to monitor devices in my environment. I have this installed on an Ubuntu Server 14.04.3 LTS. I am seeing some inconsistent data between two devices. I have the devices connected through a fiber connection. 1 device is a Cisco Nexus 7000 and the other device is a Cisco cpt 600. I am using 1.3.6.1.2.1.31.1.1.1.6. for my input string and 1.3.6.1.2.1.31.1.1.1.10. for my output string. When I make a graph showing the in from the 7k and the out from the cpt, they should look almost identical. Also when I make a graph showing the in from the cpt and the out from the 7k it should be the same. I am just focusing on the interface to interface traffic. I have seen this in multiple places across my domain. I have verified that I am using the right end string for the interfaces.
    The items are configured as follows:
    Numeric (unsigned)
    Data type decimal
    Units are bps
    I am using a custom multiplier of 8
    my update interval is 30 seconds
    Store value Delta (Speed per second)
    Show value As Is
  • troffasky
    • Jul 2008
    • 639
    How does the inconsistency manifest itself? Holes in the graph? Mismatched scale of the data at each side? Completely different data?
    • dalamar
      • May 2016
      Troffasky the data is completely different.
      I cannot find any similarity in anything. There are HUGE differences. This is what the numbers look like right now.
      CPT out 6.02 mbps
      7K in 2.18 mbps
      CPT in 227.78 mbps
      7K out 143.62 mbps
      I have similar things all over.
