Monitor VMs in Private Subnet
  • imtiaza
    • Feb 2023
    Dear Gurus,
    Please see that i have configured the Zabbix to monitor the VMs in Cloud.
    The issue is How can i monitor the VMs located in Private Subnet.
    Public has internet so no issue with them will install the agent and it will be configured on Zabbix Server and will collect the states.
    What about he Private Subnet VMs.
    Malik Adeel Imtiaz
  • guille.rodriguez
    • Jun 2022
    • 120
    I think you need to install agent and make Active Monitoring (VM sends info to Zabbix) instead Passive (Zabbix ask for info to VM)
    Active Monitoring -> No need to open any port in router/firewall. The connection is from VM to Zabbix
    Passive Monitoring -> You need to open tcp/10050 (default port) on firewalls to let Zabbix server reach Zabbix Agent installed on VM. The connection is from Zabbix to VM
    Just install Agent and select Template Linux Active or Template Windows Active
    • imtiaza
      • Feb 2023
      Thanks guille.rodriguez for your reply.
      Please confirm if Zabbix_Proxy is a solution for my issue.
      If i am thinking correctly.
      Malik Adeel Imtiaz
      • guille.rodriguez
        • Jun 2022
        • 120
        If all VMs are in same private network (or under same wan connection but in diferent vlans), yes, it's better install a zabbix proxy (active mode) and secure it with psk.
        I was thinking about cloud vms but in diferents private subnetworks, but yes, for a building , 1 proxy its a better way.
        Also you can tell to computers to send info in active mode, so proxy hardware requierements will be less than passive monitoring, ofc SNMP , WebMonitoring is polling
        Check my recent post
        In my work, we have 4 proxies, 1 for every headquarter (every hq has many vlans)
        • imtiaza
          • Feb 2023
          Thank you so much.
          guille.rodriguez
          I got Confused.
          So for on-premise Private Subnet VMs (having no internet) we use Proxy Model and for VMs located in Cloud Private Subnet we will use different model.
          Am i right ?
          Adeel Imtiaz
          • guille.rodriguez
            • Jun 2022
            • 120
            Let me explain
            Zabbix server is on cloud too? Then Cloud VMs with internet send info to zabbix server (active or passive)
            Zabbix Proxy on private subnet, needs to connect and talk with Zabbix server, so if Zabbix server is on cloud, Proxy needs internet access.
            All vms in private subnetwork will be monitored by proxy (but proxy just recolletcs info and send to zabbix server, who processes triggers, etc... and have web interface)
            https://www.zabbix.com/documentation...xies/proxy.png
            As you can see in image, proxy needs to connect to server, but other vms or computers on subnet will be monitored by proxy (VMs don't need internet access because they dont talk with zabbix server, they talk with proxy, zabbix proxy acts as a proxy)
