6.2 How to change the dashboard widget refresh interval to less than 5s
  • cnwangxp
    • Feb 2023
    Real-time monitoring of the dashboard is required due to demand
    zabbix 6.2
    Do you check all those items also with less than 5s interval? What would be the point of constant refreshing, if data itself does not change ..?
    • santosra02
      • May 2023
      • 21
      zabbix 6.2
      Just a warning, by doing that you are about to flood your database with many SELECTS (take a look in the CPU of you database server) , your Web Front-end Server with even more requests and very probably it will cause a 504 Timeout or Bad Gateway.
      When you share the dashboard set up with10s of refresh-interval between the users, the dashboard will act like a DDOS attack (conceptually speaking).
      In the best scenario, only that dashboard will turn irresponsive for anyone who try to use it, other dshboards will keep working with a little lag in the refresh.
      Well, my team and me spend almost 15h to find that after a Level 1 analyst made a dashboard with 10s of refresh-interval and raise the hell in our ZABBIX production environment.
