Zabbix HA Cluster for SNMP hosts
  • Catwoman
    • Feb 2023
    I have recently configured the HA cluster on Zabbix 6.0 and I have to monitor network devices via SNMP. I have configured network devices via SNMP before but right now with the HA cluster, I am a bit confused how will the failover work or how am I suppose to configure the devices to sync data on both nodes alternatively? Will it automatically detect the active node or is there any process to do that?
    Same question regarding addition of web URLs as well ! Can anyone please help?
    HA is not universal, it will only switch over server processes. Your snmpd things are for you to resolve. Maybe You can run it on both hosts and configure your devices to send traps to both hosts... I don't know really..
    Or add a proxy, which will accept snmp traps. set all those network devices to be monitored by that proxy.
    And what kind of web urls we are talking about ? As said.. Zabbix HA solution works ONLY for server processes, nothing else... Simplest way again... set your GUI running on separate host. In case of HA server you should do it anyway.. not run GUI on both servers...
