Zabbix ICMP Ping still works?
  • georged7
    • Mar 2023
    Hello everyone,
    I have installed Zabbix latest server (version 6.2) and testing it to see if I can monitor some hosts via ICMP simple check with Ping, I have setup the host properly, enabled the permissions for fping, verified everything and I can see that the hosts was only pinged 3 times by Zabbix... as seeing on the image attached, the server has been running for at least 1 day and the data has not updated, nor increased, any suggestions how to make it update? Ping the hosts? Thank you
    • 4957
    How do you get "only 3 times" from that pic? "Latest data 3" means there is data for 3 items... You should maybe click on that link and check the real data... ?
    • Michał Czerniakiewicz
      • Feb 2023
      • 17
      ICMP simple checks are still part of basic functionality in current version. Please try to follow this step by step tutorial(https://techexpert.tips/zabbix/zabbix-icmp-ping-monitor), check your setup and let us know if helps you.​
      • ELIAS HARO
        • Mar 2023
        I have version 6.4, I just started with Zabbix and I like it a lot, but I followed the steps in the link indicated by Michal Czerniakiewicz, followed the steps one by one and it doesn't work for me, is it different in 6.4?
        Thank you all,​
        • msteenblok
          • Mar 2023
          I also just started with Zabbix yesterday, version 6.4.0, and the first thing I tried was to setup and ICMP ping. It turns out that there is a known bug in 6.4 that makes the ICMP ping difficult to setup - see bug report https://support.zabbix.com/browse/ZBX-22105.
          In order to get it working I had to go to Data collection - Hosts - click on items link in host list - then in items list, click on 3 dots and select Configuration-Item, then set the host interface. I had to do this for all three (ICMP loss, ICMP ping, and ICMP response time).
          Hope this helps.​
          • ELIAS HARO
            • Mar 2023
            Correct, that's how it worked for me, msteenblok, thanks for the help.
            Greetings,​
