MongoDB template not working in Zabbix 6.4?
  • ezols
    • Dec 2021
    • 33
    Hello, im having problems with template "MongoDB node by Zabbix agent 2" on Zabbix 6.4 - agent version on mongo host - Zabbix Agent 2 (6.4.0)
    I have set macroces and have tested that user can login into mongodb
    agent working on mongodb
    But when i check items of mongo db template i see that all of the items are not supported:
    also ​
    ​if i want to do a test from zabbix host to mongo db with:
    zabbix_get -s xxx.xxx.xxx.xxx -k 'mongodb.ping["tcp://xxx.xxx.xxx","zabbix_mon","xxxxxxxx"]'
    I get - ZBX_NOTSUPPORTED: Unknown metric mongodb.ping
    Is it possible to monitor mongodb from zabbix 6.4?
    Thanks in advance.
    Why bother reading docs, if you can post on forums...
    Mongodb plugin is not "built-in" any more ... since 6.0.6, which came out before 6.2 final, which means it was never a built-in on 6.2 and further also on 6.4...
    You need to enable it in config... https://www.zabbix.com/documentation...mongodb_plugin
  • ezols
    • Dec 2021
    • 33
    Hi, thanks for the tips. All sorted now.
    • kyabolu05
      • Mar 2023
      The server can be happily running with a database that is not open. So it certainly does make sense to monitor the db. The fact that the processes run does not mean the db is usable.
      • durantapatra
        • Apr 2023
ID:	463715Can you please guide on MongoDB​ configuration for host "qa-mongo-1a".
