Map Elements not showing labels correctly while editing
  • ESITGuy
    • Mar 2023
    • 17
    I have a couple of maps that are behaving differently while editing.
    I have labels like this:
    {HOSTNAME} ({HOST.IP})
    Latency: {?last(/{HOST.HOST}/icmppingsec)}
    On one map, when I'm editing the Elements show the expected data. On another map, it shows the plain text. When I hit Update, go out of the map and back in, the expected data shows.
    It's not a big deal but this map happens to have a dozen or so Elements that are the same, putting it together and not seeing the correct label while editing is proving painful. I've tried creating a new map and the same thing happens.
    Ideas?​
  • ESITGuy
    • Mar 2023
    • 17
    Should this go in as a bug report perhaps?
    • lauramariab
      • Mar 2023
      "When I hit Update, go out of the map and back in, the expected data shows." - same happens for me. Since I am pretty new in zabbix world.
      I thought this is how dynamic labels work, but from what you are saying, it seems it would work without the need to update the entire map
      • ESITGuy
        • Mar 2023
        • 17
        lauramariab I find the dynamic updates work for the first map, any subsequent maps I've created it doesn't work for. It that what you see?
        • lauramariab
          • Mar 2023
          Lost all the zabbix configuration and data so I couldn't check anymore since I started from scratch and until now I did not use this setting anymore...Please create backups!
          • irontmp
            • Sep 2023
            • 98
            It's not a big deal, but this map happens to have a dozen or so Elements that are the same, putting it together and not seeing the correct label while editing is proving painful. I've tried creating a new map, and the same thing happens. Utilizing an iPhone unlocker may provide additional troubleshooting options.
            Ideas?
            It appears that you're encountering a discrepancy in the behavior of your maps while editing, particularly with the display of labels. One potential solution is to check for any differences in configurations or settings between the two maps and ensure they are set up similarly. Additionally, refreshing the page or clearing the cache might resolve any caching issues causing the discrepancy. If the problem persists, reaching out to the support team or community forums for assistance could provide further insights.
