Add name to switch port in Zabbix
  • DanSmolik
    • Mar 2022
    Hello, Is possible add description or name to port of switch monitored by Zabbix. Eg. interface name GigabitEthernet1/0/1 I wold like give the OutgiongInterface name. Is this possible ? I know that some modern switches have ability give name to port and after this I can read this via SNMP. But my switch are old and does´t have this functionality.
    Regards
    Dan
  • guille.rodriguez
    • Jun 2022
    • 120
    In some switches you can add a display-string or labrl, and zabbix grabs this label
    • DanSmolik
      • Mar 2022
      I know but my DGS-1210-48 doesn´t have this features.
      • guille.rodriguez
        • Jun 2022
        • 120
        mmmm then when zabbix discover all interfaces you can disable autodiscover and rename the item on zabbix
        • DanSmolik
          • Mar 2022
          Good idea. But when I disable aitodiscover can I get information about port UP or DOWN ?
          • guille.rodriguez
            • Jun 2022
            • 120
            The item is created, so I think the answer is YES.
            Just ensure that you have all the ports discovered.
            • DanSmolik
              • Mar 2022
              Thanks I try this. And let you know if it works.
