Dashboard for ICMP ping
  • ihtus
    • Mar 2023
    I've created a new template "ICMP Ping - no alert", that is same as "ICMP Ping" but it doesn't send email and doesn't display the host under main Dashboard when a host goes offline.
    The reason of using this template: I don't need to see the hosts under this template on the main problem dashboard, and we don't need to raise an offline alert.
    Is there a way to have a list of hosts / dashboard and show the status: online / offline based on ICMP ping?
    I am not asking for graphs / latest data of ICMP ping for a specific host, but a list of hosts with current ping status.
  • ihtus
    • Mar 2023
    Is it possible to have a column with ping status?
    • Hamardaban
      • May 2019
      • 2714
      • ihtus
        • Mar 2023
        Looks like this patch is NOT for newer versions of zabbix
        • Hamardaban
          • May 2019
          • 2714
          In the same topic it is written why this happened.
          Monitoring the status by icons is a dead end - use triggers and events
