Hello guys,
Im very frustrated. In my cluster ive setup an zabbix proxy. It is reporting to my zabbix server. All images/container are running on latest within Zabbix 6.0 LTS.
I want to get SNMP Metrics from an iDrac 9...Which runs good with snmpv2. But in snmpv3 i got all the time:
Cannot connect to "xxx.xxx.xxx.xxx:161": Authentication failure (incorrect password, community or key).
Ive checked the password and user more than once. Ive checked also the service itself and the permissions/snmpv3 enabled.
Locally i can run an snmpwalk with success...
But on a snmpwalk ive set only "SHA" and "AES". What kind i should select in zabbix? There is not that simple "SHA" or "AES".
What can I do for deeper analyzis?
I ran following command:
