How to reduce Zabbix agent active connections
  • Eike
    • Mar 2023
    I would like to reduce the many connections of the agents(6.4 active) to the server.
    The default template "Linux by Zabbix agent active" is used for comparison:
    On a system with 91 items I get in a 12h time window about 14000 connections.
    A reduction of the intervals in the template (1m to 5m) brought a reduction to about 10000 connections.
    With activating the buffering on the agent side (BufferSend=300 BufferSize=1000) I could even reduce the connections to about 8000 connections and this even with a 1 minute interval.
    Although the buffering is set to 5 minutes, the agent still sends every 5 seconds. It should not be a heartbeat, which I had also set to several minutes in a test, without this having any effect.
    Are there any other settings to get the agent to collect the items and send them as a bundle to the server?
    I would be very grateful if someone has a tip on how to further reduce the number of connections without losing data.
    Cheers
    Eike
