Dear community,
the templates I found for MongoDB are for the use with Agent2. Could I use them with an Agent1 as well, will just loose some items? Or is it in general not possible to use an Agent2-Template with Agent1?
Sorry, I do not know in detail the difference between agent1 and agent2.
If it is only possible with agent2.... how does it work... do I have to REPLACE agent1 or can they exist parallel?
If I have to replace the older agent1, I would have to do all the amandments on the agent1.conf again for an agent2.conf?
Thanks in advance for your help
Heinrich
Heinrich
