Zabbix agent 6-0-4 Debian 10 buster problem during installation
  • JackoAC
    • May 2023
    • 35
    Hello everyone,
    I recently installed a zabbix server, I managed to monitor Windows hosts without any problems and some Linux ones.
    However I have a problem with a Debian 10 buster machine which is our BlueMind mail server.
    Server information :
    Zabbix 6.0.17 on Debian 11 bullseye
    Agent information :
    Debian 10 buster, agent 6-0-4
    when I install it I get this error​ just after the command "apt install zabbix-agent"
    dpkg: zabbix-agent package processing error (--configure)
    So I looked at the logs of my agent and I have this message
    "Zabbix-agent.service: can't open PID file /run/zabbix/zabbix_agentd.pid (yet?) after start: no such file or directory
    zabbix-agent.service: Failed with result 'protocol'
    failed to start zabbix agent"
    I did some research on this error but without finding a solution.
    I tried to reinstall the agent from a previous version but the error comes back.
    The status on my agent is "loaded: loaded"
    Could you guys help me ? Thank in advance.​
  • Answer selected by JackoAC at 24-05-2023, 08:30.
    JackoAC
    • May 2023
    • 35
    You can find the real question here
    • JackoAC
      • May 2023
      • 35
      Error during install
      On the first we can see the error i get when trying to install
      When i try to start the agent
      Here what happens when i try to run the agent like nothing happened
      Thank in advance for you science.
      • JackoAC
        • May 2023
        • 35
        Found out i'm not in zabbix troubleshooting and problems, my bad sorry
        • JackoAC
          • May 2023
          • 35
