Zabbix not pulling Data from SNMP OID
  • LukeAB93UK
    • Jun 2023
    • 72
    Hey Guys,
    I have an interesting problem here on Zabbix Zabbix 6.0.9.
    I am trying to pull this value from a Juniper SRX 320 router running JUNOS 21.3R1.9.
    Click image for larger version  Name:	image.png Views:	0 Size:	4.0 KB ID:	465399
    I can using the above command I can see the raw data and the router has SNMP configured as "read only" using udp on port 161 with an snmp community user to be able to poll the information.
    ​Now we do employ Zabbix Proxies and the host that this proxy is on Centos.
    When I click on "Get Value and Test" I am greeting with this error message.
    I was wondering if there is something we missed or things we can check because I am starting to think the problem lays either with our Zabbix Server or Proxies so I am just wondering if there are things we should check because this data is just simply not coming through.​
  • Atsushi
    • Aug 2013
    • 2028
    Try specifying the following OIDs.
    1.3.6.1.2.1.10.94.1.1.5.1.2.550​
    • LukeAB93UK
      • Jun 2023
      • 72
      Hey there.
      I have also tried that as well with the same result.
      I tried to pull the information on one of our Zabbix procies too with same results
      Part of me is thinking our proxy is misconfigured but im now to this so not entire sure where to look if im being honest.​
      • Hamardaban
        • May 2019
        • 2714
        Pls try "snmpwalk yours_creditans -Ona 1.3.6.1.2.1.10.94.1.1.5.1" and show the output
        Or just try the OID 1.3.6.1.2.1.10.94.1.1.5.1.2.550​.0
        • LukeAB93UK
          • Jun 2023
          • 72
          I am just getting this output.
          snmpwalk 10.x.x.x <SNMPCommunity> -Ona 1.3.6.1.2.1.10.94.1.1.5.1
          <SNMPCommunity>: Unknown Object Identifier (Sub-id not found: (top) -> <SNMPCommunity>)
          • markosa
            • Aug 2022
            • 107
            Do you have some rules in Juniper so that community used isn't allowed to read those values? Can you read any information using that community from zabbix proxy?
            • LukeAB93UK
              • Jun 2023
              • 72
              Yes I am.
              If I run snmpwalk I can pull data.
              [user@zabbixproxy02 ~]$ snmpwalk -c <community> -v2c <IP Removed>
              SNMPv2-MIB::sysDescr.0 = STRING: <removed>
              SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.2636.1.1.1.2.134
              DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (37780972) 4 days, 8:56:49.72
              SNMPv2-MIB::sysContact.0 = STRING:
              SNMPv2-MIB::sysName.0 = STRING: <removed>
              SNMPv2-MIB::sysLocation.0 = STRING:
              SNMPv2-MIB::sysServices.0 = INTEGER: 4
              IF-MIB::ifNumber.0 = INTEGER: 58
              IF-MIB::ifIndex.3 = INTEGER: 3
              IF-MIB::ifIndex.4 = INTEGER: 4
              IF-MIB::ifIndex.6 = INTEGER: 6
              IF-MIB::ifIndex.7 = INTEGER: 7
              IF-MIB::ifIndex.8 = INTEGER: 8
              IF-MIB::ifIndex.9 = INTEGER: 9
              IF-MIB::ifIndex.10 = INTEGER: 10
              IF-MIB::ifIndex.11 = INTEGER: 11
              IF-MIB::ifIndex.12 = INTEGER: 12
              IF-MIB::ifIndex.15 = INTEGER: 15
              IF-MIB::ifIndex.16 = INTEGER: 16
              IF-MIB::ifIndex.21 = INTEGER: 21
              IF-MIB::ifIndex.22 = INTEGER: 22
              IF-MIB::ifIndex.251 = INTEGER: 251
              IF-MIB::ifIndex.501 = INTEGER: 501
              IF-MIB::ifIndex.502 = INTEGER: 502
              IF-MIB::ifIndex.503 = INTEGER: 503
              IF-MIB::ifIndex.504 = INTEGER: 504
              IF-MIB::ifIndex.506 = INTEGER: 506
              IF-MIB::ifIndex.507 = INTEGER: 507
              IF-MIB::ifIndex.508 = INTEGER: 508
              IF-MIB::ifIndex.509 = INTEGER: 509
              IF-MIB::ifIndex.510 = INTEGER: 510
              IF-MIB::ifIndex.511 = INTEGER: 511
              IF-MIB::ifIndex.512 = INTEGER: 512
              IF-MIB::ifIndex.515 = INTEGER: 515
              IF-MIB::ifIndex.516 = INTEGER: 516
              IF-MIB::ifIndex.517 = INTEGER: 517
              IF-MIB::ifIndex.518 = INTEGER: 518
              IF-MIB::ifIndex.519 = INTEGER: 519
              IF-MIB::ifIndex.520 = INTEGER: 520
              IF-MIB::ifIndex.521 = INTEGER: 521
              IF-MIB::ifIndex.522 = INTEGER: 522
              IF-MIB::ifIndex.524 = INTEGER: 524
              IF-MIB::ifIndex.525 = INTEGER: 525
              ^C
              • LukeAB93UK
                • Jun 2023
                • 72
                i have made a discovery.
                I used SNMP walk on my Juniper Device and pulled the OID for the ADSL speed I am trying to monitor and Zabbix is still returning no such object at this OID
                As you can see the OID I have been using is correct.
                I randomly grabbed anorther OID from a different value I came across when doing an SNMP walk.
                • Hamardaban
                  • May 2019
                  • 2714
                  1) Please check
                  Originally posted by markosa View Post
                  Do you have some rules in Juniper so that community used isn't allowed to read those values?​
                  2) From www.juniper.net/documentation
                  What can I do if the MIB OID query is not responding?
                  There can be various reasons why the MIB OID query stops responding. One reason could be that the MIB itself is unresponsive. To verify that the MIB responds, use the show snmp mib walk | get MIB name | MIB OID command:
                  • If the MIB responds, the communication issue exists between the SNMP primary and SNMP agent. Possible reasons for this issue include network issues, an incorrect community configuration, an incorrect SNMP configuration, and so on.
                  • If the MIB does not respond, enable SNMP traceoptions to log PDUs and errors. All incoming and outgoing SNMP PDUs are logged. Check the traceoptions output to see if there are any errors.
                  If you continue to have problems with the MIB OID query, technical product support is available through the Juniper Networks Technical Assistance Center (JTAC).
                  • LukeAB93UK
                    • Jun 2023
                    • 72
                    So I have made some progress. I have got the proxy to pull the string.
                    However even if I specify the ifIndex of the interface
                    Click image for larger version  Name:	image.png Views:	0 Size:	1.8 KB ID:	465598​
                    or not
                    Click image for larger version  Name:	image.png Views:	0 Size:	1.7 KB ID:	465599​
                    I am still getting "
                    • No Such Instance currently exists at this OID
                    ​I am legitimatey now at a total loss on how to get that string to dump that info into my Zabbix instance.​
                    • Hamardaban
                      • May 2019
                      • 2714
                      The difference is that snmpwalk runs down the tree from the specified OID, while zabbix "uses" snmpget which requests the specified value.
                      From proxy try "snmpget yours_creditans -Ona yours_IP 1.3.6.1.2.1.10.94.1.1.5.1.2.550.0" and if you get a value, use exactly this OID in zabbix.
                      • LukeAB93UK
                        • Jun 2023
                        • 72
                        Hey there,
                        I ran that exactly from the proxy and I got this
                        snmpget <MyCommunityString> -Ona <MyIP> 1.3.6.1.2.1.10.94.1.1.5.1.2.550.0
                        snmpget: Invalid address (<MyCommunityString>) (Resource temporarily unavailable)
                        • LukeAB93UK
                          • Jun 2023
                          • 72
                          I ran this command with -Ona I had to specify -v2c and -c
                          snmpget -v2c -c <MyCommunityString> -Ona <IP Address> 1.3.6.1.2.1.10.94.1.1.5.1.2.550.0
                          .1.3.6.1.2.1.10.94.1.1.5.1.2.550.0 = No Such Instance currently exists at this OID
                          Yet with an SNMP walk it shows the value
                          snmpwalk -v2c -c <MyCommunityString> <IP Address> .1.3.6.1.2.1.10.94.1.1.5.1.2
                          SNMPv2-SMI::transmission.94.1.1.5.1.2.550 = Gauge32: 8544000
                          Not sure if im doing or have done something wrong but I can pull the value 8544000 with walk but not with get.
                          • Hamardaban
                            • May 2019
                            • 2714
                            if you zabbix version gt 6.4 you can use new feature https://www.zabbix.com/documentation...snmp_oids_walk
                            • LukeAB93UK
                              • Jun 2023
                              • 72
                              #15
                              And doing this would allow me to "walk" and get the value instead of get correct?
